Deletes a default blackhole route from the routing table.
| vr_name | Specifies the VR or VRF from which the route is deleted. |
If you do not specify a VR or VRF, the current VR context is used.
While a default route is for forwarding traffic destined to an unknown IPv6 destination, and a blackhole route is for discarding traffic destined to a specified IPv6 destination, a default blackhole route is for discarding traffic to the unknown IPv6 destination.
Using this command, all traffic with an unknown destination is discarded.
The default blackhole route is treated like a permanent entry in the event of a switch reset or power off/on cycle. The default blackhole route's origin is "b" or "blackhole" and the gateway IPv6 address for this route is "::."
The following example deletes a blackhole default route from the routing table:
configure iproute delete blackhole default
Support for IPv6 was added in ExtremeXOS 11.2.
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
